what the hell is this thing? https://ausmini.com/forums/viewtopic.php?f=5&t=13085 |
Author: | inazuma_x [ Sat Nov 12, 2005 7:50 pm ] |
Post subject: | what the hell is this thing? |
is this a brake booster or something? http://imagestore.ugbox.net/aview/eedb2 ... f47fbaa17e it seems that i have to remove it in order to get the front subframe out...is this the case? |
Author: | monrel [ Sat Nov 12, 2005 7:55 pm ] |
I think it's a horn. |
Author: | inazuma_x [ Sat Nov 12, 2005 7:58 pm ] |
spose that would make sense...i'll take it out either way ![]() |
Author: | mickmini [ Sat Nov 12, 2005 8:22 pm ] |
yep its a horn - never seen one down there before though |
Author: | meeni [ Sat Nov 12, 2005 8:37 pm ] |
yer thats the horn, my deluxes one is there too, thats the only mini that has em there i think, the rest are on the other side on the inner guard to my knoledge, but yer, just a horn |
Author: | drmini in aust [ Sat Nov 12, 2005 8:41 pm ] |
BMC carefully positioned it there to make it bloody near impossible to get the oil filter out. Without spilling it. ![]() I guess at least it doesn't crack the bodywork and fall off, like Clubby ones- including ours did. ![]() |
Author: | inazuma_x [ Sat Nov 12, 2005 11:39 pm ] |
was a bit surprised...especially since the passenger side brake lines go right under it...hence why i thought it was a brake booster or something...do i just undo the nut ontop? or is there some other way of getting it off? |
Author: | gafmo [ Sun Nov 13, 2005 5:30 am ] |
its attched to the subframe underneath..nut and bolt get the jack and axle stands out ![]() |
Author: | clubby123 [ Mon Nov 14, 2005 7:38 pm ] |
hehe yer definately a horn ![]() |
Author: | inazuma_x [ Tue Nov 15, 2005 7:57 am ] |
can it be reconfigured to play la cucaracha? ![]() |
Author: | Matt68 [ Tue Nov 15, 2005 1:37 pm ] |
Hi Just get a 7/16 socket (1/4" drive is best with a 2" extension.) into the spce under the lip of the subframe to hold the nuts, then use a 7/16" spanner to turn the bolt on the outside of the subframe and the whole thing lifts away. (2 bolts in the horizontal plane) Matt |
Author: | Lillee [ Tue Nov 15, 2005 8:23 pm ] |
Go air horns! if they can't see you, they definately will hear you! ![]() |
Author: | inazuma_x [ Wed Nov 16, 2005 7:56 am ] |
as long as they play la cucaracha....I'M THERE! |
