https://ausmini.com/forums/
SC12 on which engine?
https://ausmini.com/forums/viewtopic.php?f=5&t=13050
Page 1 of 2
Author:  Konzo [ Fri Nov 11, 2005 10:18 am ]
Post subject:  SC12 on which engine?
Which engine would I be better off running an sc12 supercharger on? Fuel efficiency isnt really a concern ... i want a car that'll be quick
Author:  awdmoke [ Fri Nov 11, 2005 11:36 am ]
There will be a bigger gain in torque with a 1275 (or 1330)
You will hardly find any 1275 blocks around on their original bore
- just take to the next oversize, 1310 , 1330
Author:  benjamin [ Fri Nov 11, 2005 11:54 am ]
id do an 850 just to be different and you can pick up one for nothing :wink:
Author:  Konzo [ Fri Nov 11, 2005 5:08 pm ]
I dont want to be "different" ... i want something with POWER!
Author:  Mini Mad [ Fri Nov 11, 2005 6:08 pm ]
there ain't no substitute for 'cubes ;)
Author:  Konzo [ Fri Nov 11, 2005 6:09 pm ]
I was thinking 1330 with sc12 running through a weber or delorto ... but kinda heard that a 998 with an 1100 head was good too?
Author:  Mini Mad [ Fri Nov 11, 2005 6:14 pm ]
good luck getting it to work with a webber or dellorto..i'd like to see it done 8)
a 998 may be good, might make similar power to an Naturally Aspirated 13XX...
Author:  Konzo [ Fri Nov 11, 2005 6:16 pm ]
Just because its what i want, doesnt mean itll happen :)
Author:  awdmoke [ Fri Nov 11, 2005 6:26 pm ]
My wife tells me that all the time :(
Author:  Konzo [ Fri Nov 11, 2005 6:34 pm ]
Bloody minister for finance and recreation!
Author:  gafmo [ Fri Nov 11, 2005 7:48 pm ]
Ask 100 time and you get it 20 times :?:
Ask 20 time and you get it once :!:
:wink:
Author:  drmini in aust [ Fri Nov 11, 2005 8:02 pm ]
It will work fine with a Weber or Dellorto, suck-thru is easiest with a S/C.
But a big SU just as good I reckon.
Size? 1275-1330. Over that the cylinder walls are a bit thin for forced induction.
Author:  willy [ Fri Nov 11, 2005 8:18 pm ]
FFS do the maths people.
Whats gonna be quicker, standard?
an 850 or a 1275.
Hmmmm :roll:
/**** rant.
Author:  Konzo [ Sat Nov 12, 2005 8:37 am ]
Okay looks like im going to run with a 1330 and the sc12 sucking through a kick ass su carby or weber :)
Thanx guys
Lucas
Author:  marcsvenson [ Sat Nov 12, 2005 8:51 am ]
mnmmn i just looked at the results and zero for 1100s i would have thought behind a big block this would be the go because of its torque which it has standard
i would love to try one on a worked 1100
