engina reco https://ausmini.com/forums/viewtopic.php?f=5&t=12477 |
Author: | minimechanic [ Mon Oct 24, 2005 6:56 pm ] |
Post subject: | engina reco |
ok people i just wanna know if therz anytin i left out in the parts needed to recondition my 998, assuming the engine is in fairly good nick ie no rebore and pistons( cus thats a boring process haha) copy and paste any more that i forgot...... Valve Locks Valve stem seals Cam Followers but not bearings cus their hard to do but dont get worn very much Oil pump Electric fuel pump Water pump Rings Crank Journals, bearings with thrust washers to suit. Timing Chain Tensioner and timing chain Wire brushes for the head. Rings |
Author: | minimechanic [ Tue Oct 25, 2005 11:28 pm ] |
Dis is da stuff dat i need - FINAL LIST Parts that I will neeed: Valve locks, 8 pairs Valve stem seals, 8 off Cam followers, 8 off Oil pump Oil pump locktabs Main bearings Big end bearings Big end locktabs, 4 off Timing chain tensioner Double row timing chain Piston rings Flywheel ring gear Harmonic balancer locktab Timing cover oil seal Water pump Lower radiator hose Expansion hose Thermostat Gearbox input shaft/clutch housing bearing Gearbox idler gear/clutch housing bearing Gearbox/engine flange gaskets Clutch housing/engine gasket Clutch housing oil seal Clutch locktabs Clutch housing locktabs Clutch kit (pressure plate, driven plate, throwout bearing) Inner drive shaft joint rebuild kit (ball bearings?), 2 off Head port & polish kit ![]() |
Author: | TheMiniMan [ Fri Nov 11, 2005 3:24 pm ] |
oops,,,forgot the turbo & injection assys ![]() |
Author: | WhoDat [ Fri Nov 11, 2005 3:40 pm ] |
Don't forget to budget for the often overlooked Oil and filter for runin Oil and filter after runin Coolant Plugs Points? Dizzy cap and rotor? you have stated the gearbox and clutch gaskets but you're going to use an entire long motor set of gaskets Good luck with the project |
Author: | minimechanic [ Sat Nov 12, 2005 4:29 pm ] |
Did i leave out the possiblity of supercharging,nos,nah im startin the 4efte next year anyway and that will have all that..... Yeh i'll b buyin oil coolant filterz, plugs, i dont know bout the contacts as i might do a pulsar dizzy ![]() I'm hopin for the engine to be done by like end of january..that'll give me time to work on all the other little pieces of sheite thats stoppin it from passin rego Another thing that surprised me was that this engine had PERFECT Cylinders and the crank was still in spec...not too bad hey I bought meself some autometer white faced guages (oil,water,volts and tacho) just to keep me from blowin it..then i would have to start again ![]() |
