LED replacements for bayonet filament bulbs https://ausmini.com/forums/viewtopic.php?f=5&t=12285 |
Page 1 of 2 |
Author: | mickmini [ Tue Oct 18, 2005 6:43 pm ] |
Post subject: | LED replacements for bayonet filament bulbs |
Anyone tried these? http://www.ledshoponline.com/automotive_leds.htm just wondering.... |
Author: | Gordo [ Tue Oct 18, 2005 8:25 pm ] |
I havnt tried them but they seem like a good idea... I like the LED lights |
Author: | EST-071 [ Tue Oct 18, 2005 8:37 pm ] |
I run LED in brake/tail lights and parklights. They work a treat. Pete |
Author: | benjamin [ Tue Oct 18, 2005 8:58 pm ] |
whats the advantage of them? apart form looking cool |
Author: | min13k [ Tue Oct 18, 2005 9:00 pm ] |
they last longer than a fillament due to vibration thats why they are comon place on trucks nowadays makka |
Author: | poeee [ Tue Oct 18, 2005 9:11 pm ] |
In theory, an LED will never blow, unless high current or high voltage passes through them. So in normal operating conditions, they will last forever! A normal globes filament will eventually break. When a globe lights up, the filament heats up causing it to glow. When it turns off, the filament cools down. The constant heating and cooling makes the filament brittle after time, causing it to break. |
Author: | Morris 1100 [ Tue Oct 18, 2005 9:17 pm ] |
We have some trucks at work fitted with LED lights (not LED globes but the complete light) and they mostly work well but there are a couple of brands that have only lasted a couple of months. Dammed expensive when they don't work! The main reason for using them on trucks is on long trucks (trailers/B doubles) you lose voltage by the time you get to the back of the trailer and the lights are dim. With LEDs they are bright even with a couple of volts! (should work well on a mini with a generator!) |
Author: | Molina [ Tue Oct 18, 2005 11:43 pm ] |
At the prices that site is asking i'd make them myself. Buy a standard globe, a packet of LED's and whip out your soldering iron. Bust the globe and use the bayonet fitting to mount the LED's on. |
Author: | NoMoreMinis [ Wed Oct 19, 2005 6:44 am ] |
They are half that price on ebay......but even that price isnt too bad....not worth me stuffing around to try and make them. I'll definately have some in my mini....when it gets to that stage ![]() |
Author: | ausminis4u [ Wed Oct 19, 2005 9:37 am ] |
autobarn has these led bulbs in stock, also jan (mutantmini ) has these in her mini |
Author: | Mike [ Wed Oct 19, 2005 9:41 am ] |
A fair bit cheaper at Jaycar electronics - BTW Jaycar has a disclamer that these are not suitable for road use (just off road + show). |
Author: | Chris [ Wed Oct 19, 2005 11:25 am ] |
To illustrate the cost of LED light assemblies, I recently bought all the lights for my new kart trailer and they cost me $600 and that was with a substantial discount. Not cheap but they never give trouble. We have another trailer that I put some on about 4 years ago and they have never failed to work in all that time. |
Author: | Smokie [ Wed Oct 19, 2005 12:41 pm ] |
I put some LED stop lights high up on the back of the Moke... Just so no-one can say they didn't see my stop lights.. ![]() |
Author: | 1380 yellow devil [ Wed Oct 19, 2005 2:20 pm ] |
I got a set of LED repalcements and I put them in then took them out as I was not happy with the output from them as I feel that the Incandensent Bulb allow more ligh to reflect around the lens while the LED only shot the light straight out. I have been looking at getting the LED Repalcement Board for the Morris Mini with a 3 Screw Lens from Mini Maina but a little expensive. |
Author: | Mini Mad [ Wed Oct 19, 2005 3:39 pm ] |
Yes, Standard dome LED's like the ones shown only disperse and intense beam that isn't viewable from a wide angle. I'm pretty sure they are illegal too because of this. These ones below are a flat disc type LED.. ![]() They disperse the light.. Check out the Products here: http://www.ledspecialfx.com.au/products.html Main Website: http://www.ledspecialfx.com.au/ I am in no way associated with this company, though I have seen the quality of their work on show bikes and met the owner in person, nice bloke and knows what he is talking about. |
