Dashes from other cars https://ausmini.com/forums/viewtopic.php?f=5&t=11998 |
Author: | kasperflipped [ Mon Oct 10, 2005 11:05 am ] |
Post subject: | Dashes from other cars |
Hi all how hard is it and whats needed to fit a dash with instrumnents from other cars to minis? Is the wiring hard to figure out or not compatible at all for example if i wanted to install this dash from an EH into my clubbie what would i need to do? ![]() or this instrument cluster from a yamaha bike ![]() Im not saying i want either im just using them as examples thanks trent |
Author: | h0nk [ Mon Oct 10, 2005 4:45 pm ] |
I'm not too sure, never had to do one.. But if you can't work out the wiring I'd sugest getting a manual for the car the instrument cluster came off and use the wiring diagram in that to work it out. |
Author: | fuzzy-hair-man [ Mon Oct 10, 2005 5:04 pm ] |
If the speedo you are using is electronic it might be a bit more difficult (as I presume the Yamaha's speedo is). Brad just put thecluster from a Subaru in the 'basher' so he could tell you more ![]() ![]() |
Author: | kasperflipped [ Mon Oct 10, 2005 8:03 pm ] |
I cant think of why it wouldnt work, its all just 12 volt isnt it, Sure speedo cable connectors might be a lil different, but if i install a dash from another car thats a 4 cylinder theres no reason why tachos should be out is there..................hmmmmmm maybe a trip to a wrekers is in order trent |
Author: | NoMoreMinis [ Mon Oct 10, 2005 8:45 pm ] |
The tacho wouldnt be too hard to make work......but the speedo could....not all cars have speedo cables.....especially a digital dash like that bike one...it would have a speed sensor somewhere which sends mesages to the ECU....the ECU then converts that to road speed and tells the LCD what to display..... |
