OK I'm
sure I've seen this mentioned somewhere else but I've looked and searched and can't find a thing. . . .so it's time to ask. . .
A friend of mine has almost finished putting together a draw through turbo setup for his car. . .he's had a dissy from a late 80's turbo Subaru Leone (he's using this setup 'cos it has vac-advance/boost retard capabilities) modified to fit and clamp properly to the motor. . .and now it's time to wire it up. . .and for some reason this is my responsibility
He tells me that there are four wires coming out of the dissy - does anyone know anything about where they should go? I haven't even seen the setup yet, so I have no idea whether the Subaru dissy has an internal igniter (like a Pulsar unit) of needs and external one (like the Hondas).
If anyone has
any info, it would be great to hear from you. . . .
Thanks,
Pete in Perth.
