Looking for someone with KAD rear disks..... https://ausmini.com/forums/viewtopic.php?f=5&t=11202 |
Author: | Beau [ Thu Sep 15, 2005 6:43 pm ] |
Post subject: | Looking for someone with KAD rear disks..... |
I need some info. from someone that has these. REAR DISKS 1. Disk diameter 2. hub width. 3. disk width 4. brake surface wisth on disk Thank you for your help. |
Author: | TheMiniMan [ Thu Sep 15, 2005 9:08 pm ] |
don`t think there`s that many people here who have a money tree to be able to afford them ![]() Make em yourself easy enough to fabricate from 2nd hand stuff from the wreckers & whip up a billett alloy rear hub for it easy-peasy i used to make alloy rear hubs, but only stock looking ones,,,been meaning to set up for a disc flange on the back of the next set i machine up tho |
Author: | Harley [ Thu Sep 15, 2005 10:09 pm ] |
I've got spare discs floating around here for the front of a car. How does the handbrrake usually connect up with discs? I'm not going to do a conversion, but I wondered if it can be done. |
Author: | Beau [ Fri Sep 16, 2005 4:41 pm ] |
I'm going to build my own, with a hydro hand brake on a seperate system. Similar to rally cars. I plan to use a motorcycle rotor, but would like to know what diameter the KAD ones are. I think a 6-8" -1/4" rotor will do. I believe the KAD disks have a cable hook up as well, which I won't be able find I don't think. There are a few people I have emailed, but no replies yet. TheMiniMan- Do you know the dimensions off hand for the inner cavity where the bearings sit? I still have to press out the bearing on my hubs, but if I could just get the dimensions, that would save a little time. |
