https://ausmini.com/forums/
Starter Motor Alternatives
https://ausmini.com/forums/viewtopic.php?f=5&t=11151
Page 1 of 2
Author:  awdmoke [ Wed Sep 14, 2005 11:25 am ]
Post subject:  Starter Motor Alternatives
OK, so once you've got a nicely worked high compression big block you find the OE starters just don't cut it. What other alternatives are there besides the Gemini starter?
I hear someone has details on a Honda unit that fits...
Author:  Mini Mad [ Wed Sep 14, 2005 1:24 pm ]
Heritage MG Sell a very good pre-engaged starter for $160 2-year warranty.
Author:  gafmo [ Wed Sep 14, 2005 1:38 pm ]
Or the Gemini starter..ill have to do that soon
Author:  awdmoke [ Wed Sep 14, 2005 1:57 pm ]
Post subject:  Honda Starter - thanks to TK
Here are the Honda starter motor conversion details, thanks to TK
With the help of Scooperman and Brucie in the 'Toon, I went to the boneyard this morning in search of a Honda starter motor. Between the Accord(ian)s and Civic's I found a decent looking rebuilt one. It only took a few minutes to take it out, once I figured out that it has a bolt coming from somewhere under the inlet manifold! I left $17.99 Cdn (including the $5 core charge) at the counter and I was away.
The engine in the dyno stand is pretty accessible, so I checked the fit there. I didn't really like the way it was sitting, so flying in the face of Scooperman's directions for mounting, I cut all the extraneous aluMINIum lugs off the mounting face. My idea was to make a flange out of aluMINIum plate and turn a hole in the centre that matched the hole in the Honda transmission, 75 mm. I grabbed a scrap Lucas starter (yea yea, cut with the jokes) and removed the mounting flange for a template. That template turned into a prototype flange when I chucked it in the lathe and cut the middle out. With that piece bolted in place, the Honda starter could be rotated around until I found a good position for it.
Unfortunately, the solenoid can only go in a couple of different positions and still allow the thing to be bolted in place. Ideally the solenoid would hang down, but that would mean that the mount bolts would have to come in from the clutch side and there's no straight path for the bolts. The prototype mount flange looked pretty good so I just welded it in place. NOTE: the Japanese aluMINIum is nice and clean, but the English stuff was just full of crap and welded quite poorly. I had to grind and reweld to get a decent finish.
The business end has the same 10 tooth drive gear and once it's centred in the hole, it engages perfectly every time. The drive doesn't extend any farther than the ring gear, so that big cone on the clutch cover can be cut off.
It sure sounds quite different from the Lucas starter! It also spins faster than the Lucas so this thing should start with fewer turns. So what's the advantage? Well besides a more reliable and available starter, it's 600 g (4.0 vs 4.6 Kg) lighter. It also eliminates the Lucas solenoid, an item that constantly causes irritation. Sure it took a couple of hours to fabricate a mount to bolt into the Mini transfer case, but if I ever need to rebuild this thing, I can keep the one unique part and change everything else. Easy!
Author:  1380 yellow devil [ Wed Sep 14, 2005 3:03 pm ]
http://www.castleauto.com.au/starters.htm
Check this out as well Look the same styles as above but $350
Author:  awdmoke [ Wed Sep 14, 2005 3:31 pm ]
$350 ??? They are new, but $350 ?
Gemini starter still looks like the cheapest & easiest, but I might ring around & see what used Honda starters go for...
Author:  poeee [ Wed Sep 14, 2005 4:29 pm ]
The good thing about the Gemini starter is that it pulls its gear in from the other side to a normal Mini starter. That means if the teeth on the flywheel are stuffed and your starter isn't working too good because of it, try a Gemini starter, and more often that not it fixes your problem as its using the other side of the teeth on the flywheel. 8)
Author:  1380 yellow devil [ Wed Sep 14, 2005 4:43 pm ]
Ordered one today and I wll have it by friday and I will let you all know how it goes.
Author:  drmini in aust [ Wed Sep 14, 2005 10:45 pm ]
Which one? :lol:
BTW how are the Toyota rockers- on yet? :P
Author:  1380 yellow devil [ Thu Sep 15, 2005 7:58 am ]
Which one? :lol:
One for Castle Autoelectrics and it is GR2/MK1 Escort.
The rockers should be going on this weekend As bee to busy to get them fitted.
Author:  1380 yellow devil [ Fri Sep 16, 2005 2:02 pm ]
Mine Arrived today It is a lot smaller and Will be on Tomorrow morning.
It does look very similar to that honda one.
Author:  awdmoke [ Fri Sep 16, 2005 2:33 pm ]
Nice - you'll have to post pics & let us know how well it works.
Author:  1380 yellow devil [ Fri Sep 16, 2005 2:42 pm ]
Yeah I will take some before I put it on and after it is on
Author:  Beau [ Fri Sep 16, 2005 5:20 pm ]
Hey, I posted this in the Mod forum, and didn't really get an answer besides "get the gemini", which is a pain the the hole for me in the US. Any idea what exact model/year TK got the starter off of?
Author:  awdmoke [ Fri Sep 16, 2005 5:41 pm ]
The pics shown here are of a Honda Civic starter.
TK actually used a Toyota starter (Honda parts are expensive in Oz). Many of the NipponDenso starters will fit using this method. TK's tip was to pick the ones with the longest possible "nose" so you can get the best engagement, especially if you mini has a 3/8" flywheel.
