Christoph wrote:
I have a 1/2" lobe camshaft but it has some rust damage and looks as though it needs to have its journals reground otherwise it is scrap. Does anyone know if they make undersize 1275 camshaft bearings?
Otherwise i will have to find another 1/2" lobe cam or will GR do a surcharge arrangement?
thanks
You can get .010" undersize bearings, I did it once for the same reason, but I would suggest you don't go there. Any cam you choose to fit in future would also need grinding .010". PITA..
Just ask here for another cam- is it pin or star drive?
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
