It is currently Mon Jun 30, 2025 5:27 am
PostPosted: Tue Sep 13, 2005 9:48 am
Hi:
I searched threads and I can't readily see the answer to this.
Mark I Cooper S. Re-wiring dash. Temperature gauge has a wire going to temperature sender unit on block, another wire going to instrument regulator. Which wire goes on which terminal?
Same question for fuel gauge - wire going to sender unit in tank, another wire going to instrument regulator. Which wire goes on which terminal?
I cannot see any markings on the gauges such as + and - to label the terminals.
Thanks
PostPosted: Tue Sep 13, 2005 10:12 am
See my reply under Mini Chat
Regards
RonR
