https://ausmini.com/forums/
SU 1.5" on a 1098
https://ausmini.com/forums/viewtopic.php?f=5&t=10822
Page 1 of 2
Author:  sebatron [ Mon Sep 05, 2005 7:18 pm ]
Post subject:  SU 1.5" on a 1098
what's the deal with putting an SU 1.5" onto a 1098?
That's a pretty broad question, perhaps I'd better narrow it down a touch:
-what are the benefits?
-does it sound better? :)
-what needle/jets etc would anyone recommend for a stockie 1098?
-do they fit on a standard manifold or do i need to get crafty?
I managed to pick up a pair for a pittance... Figure I'd best rebuild them and place at least one on my motor, god knows it needs a tune as it is anyway.
(yay for more silly mininewbie questions!)
Author:  drmini in aust [ Mon Sep 05, 2005 7:29 pm ]
Lots of 1098 Minis here now running an HS4 (1.5") carb.
I had one on Barney's 1098, we didn't even change the needle... and he ran OK.
Easiest way is grab a manifold off a later 998 Clubby. :wink:
It's worth about 3HP gain on the 850 (auto) and 998. Probably more on a 1098.
Author:  sebatron [ Mon Sep 05, 2005 7:35 pm ]
how about twin hs4's on a 1098? :twisted:
later 998 clubby... is that to say it wont fit my manifold? :/
Author:  drmini in aust [ Mon Sep 05, 2005 7:51 pm ]
Twin HS4s a bit big for 1098, but bobtel runs them.
Early H4 will, but HS4 used on most Minis with 1.5s have diagonal mounting bolt pattern. So grab a 998 Clubby manifold, everybody has 1-2 or 3... :lol:
Author:  Maxi23 [ Mon Sep 05, 2005 8:04 pm ]
I JUST put 1.5" carbie on my 1098 last weekend, upgraded from a 1 1/4"
I have had a BIG GRIN since it went on.
More Power.
Runs Better.
Runs Stronger.
Sounds Better.
Mine came on a manifold already, allI had to do was change the fuel bowl top to a single carbie type and I swapped over the insides of the fuel bowl with another 1.5" carbie I had.
But 1.5" carbie ROCKS!!! I love it!!
And..you can pick them up cheap.
Author:  sebatron [ Mon Sep 05, 2005 8:06 pm ]
how's the fuel economy? heaps worse?
gotta suss out a manifold.. anyone got a spare? or two? three may be excessive.
Author:  Maxi23 [ Mon Sep 05, 2005 8:14 pm ]
Well I think mine is less at the momebt, my previous carb ate fuel.
But I will be able to tell by this friday.
Author:  sebatron [ Mon Sep 05, 2005 8:31 pm ]
my 73 clubman is CHEWING through fuel - 13.9l/100 or thereabouts at last count.
can't see it getting any worse.
Author:  poeee [ Mon Sep 05, 2005 9:31 pm ]
You may find that your fuel economy could improve. It comes down to the efficiancy of the carb, so where the 1.25" may be starving the engine of air, the 1.5" will let more in without starving the engine as much. You may be supprised. 8)
Author:  Chris [ Mon Sep 05, 2005 9:32 pm ]
:shock: :shock: :shock: i've got a 308 in a Statesman that does better than that.
Author:  gafmo [ Tue Sep 06, 2005 12:04 am ]
I have a HIF44 and get 125Miles out of a 25ltrs tank
anmd we'll see what he does on the week end
Author:  sebatron [ Tue Sep 06, 2005 6:32 pm ]
update:
did 7.25l/100 last tank.
hydrospastic is at normal height, empty boot, no freeway runs... hmm.
Author:  stuvz [ Wed Sep 07, 2005 8:43 pm ]
i was wondering how much of a powergain i would get from putting a webber on my 1100. can any1 tell me if its well worth it? and compare how fast it will go compared to other little cars?
its pretty standard as it is, just got exhaust and extractors pretty much
Author:  drmini in aust [ Wed Sep 07, 2005 9:50 pm ]
I'd forget a Weber, unless you first modify the head to breathe better, and change the cam. :wink:
Author:  Spaceboy [ Fri Sep 09, 2005 4:22 pm ]
man, you need to get a tune or something if you're running over 10L/100kms
should return about 7L/100kms
the carb itself wont do a great deal unless you also put on an exhaust and extractors..
economy is about the same unless you use its full potential
