https://ausmini.com/forums/
1098 pistons/998 crank = good forced induction comp ratio?
https://ausmini.com/forums/viewtopic.php?f=5&t=10811
Author:  poeee [ Mon Sep 05, 2005 3:09 pm ]
Post subject:  1098 pistons/998 crank = good forced induction comp ratio?
I was thinking (never a good thing!).
Because the 1098 uses the same block and con rods as the 998, I was wondering what the compression ratio would be if you used a 1098 crank and the shorter 998 pistons. Would the comp ratio be suitable for forced induction and to what extent could you boost it? Would be a hell of a lot cheaper than getting deep dish pistons, thats for sure!
Ignor ALL THAT! I got muddled up... new question is this...
Because the 998 uses the same block and con rods as the 1098, I was wondering what the compression ratio would be if you used a 998 crank and the shorter 1098 pistons. Would the comp ratio be suitable for forced induction and to what extent could you boost it?
Author:  aaron [ Mon Sep 05, 2005 3:46 pm ]
You would have to deck the block quite alot to get it to run. Dropping 100ml in engine capacity that is 25ml per bore. :shock: yes it would drop your compression ratio, but i think way too much. Good idea but i think it would be easier to work the head and drop the compreesion ratio that way. maybe use thick pistons and dish them out more. Would interested to see if i am right on this, but i think i am close to the mark :wink:
aaron
Author:  drmini in aust [ Mon Sep 05, 2005 3:50 pm ]
998 pistons are 0.148" longer than 1098 not shorter, they will hang out of block. :cry:
This is `coz the stroke of a 1098 is .296" longer....
Author:  aaron [ Mon Sep 05, 2005 5:16 pm ]
as they say upside down miss jane?! Brain malfunction for me. i was thinking 1100 rods on a 998 crank :oops:
Aaron
Author:  fuzzy-hair-man [ Mon Sep 05, 2005 6:19 pm ]
1098 rods are the same as 998 rods aren't they? I thought they reduced the piston height for the 1098, so the pistons didn't come out the top of the block and the compression ratio was reasonable.
Author:  drmini in aust [ Mon Sep 05, 2005 7:23 pm ]
Yep, all A series rods (except 970S which are 1/8" longer) are the same length (5.750"). 998 & 1098 just have different pin to crown height in the pistons. :wink:
Author:  poeee [ Mon Sep 05, 2005 8:33 pm ]
I told ya it wasn't a good thing when I start thinking!
Anywho... I'll ask the question again, around the other way!
Author:  drmini in aust [ Mon Sep 05, 2005 9:08 pm ]
Depends what 1098 pistons.. I've seen some Oz ones that hardly had the crown attached to the skirts... :shock:
Assuming good ones, you would still want to deck the block, probably by .120" or so- but yes it would help lower C/R. You won't have any squish area though.
Author:  Booglie [ Tue Sep 06, 2005 7:58 pm ]
A 998 engine will run with 1098 pistons although very crappy, i had a setup like this in a van and with a 60 thou bore it had less power that an 850
Author:  poeee [ Tue Sep 06, 2005 8:27 pm ]
That is actually good news for the reason why I asked the question. The reason why it ran bad is because of the low compression, but... low compression is what you need for a turbo or supercharger... hmm...
Author:  Spaceboy [ Sat Sep 10, 2005 4:38 pm ]
unfortunately, that makes it a pig off boost
Author:  miniVan [ Mon Sep 12, 2005 1:23 pm ]
you could run some seriously high boost though..
i looked into that.. it is cheaper to deck the block than it is to CC the head too
machining the head flat (which you should do in a rbuild anyway is the same price as decking it to any height (within reason)
Author:  poeee [ Mon Sep 12, 2005 3:22 pm ]
You'd deck the head with a rebuild, well I would, it saves any possible costly implications!
Whether you'd need to deck the block much at all, you'd have to do measurements.
