Tool box for engine rebuild. https://ausmini.com/forums/viewtopic.php?f=5&t=10709 |
Page 1 of 2 |
Author: | Harley [ Thu Sep 01, 2005 9:11 pm ] |
Post subject: | Tool box for engine rebuild. |
I figure if I'm going to rebuild my 1275 myself, I'd better get the right tools for the job or know where I can get them. What will I need apart from a good socket and spanner set, and a good torque wrench? Any other tools that may not be needed, but come in useful for some of those more annoying jobs? Thanks. |
Author: | simon k [ Thu Sep 01, 2005 9:14 pm ] |
vizard's tuning BL's A series long before you start soft hammer ring compressor big protractor (none of this lining up the dots business) shrugs... |
Author: | Mini Mad [ Thu Sep 01, 2005 9:15 pm ] |
A flywheel puller springs to mind... This place seems to have cheap toolkits...I just bought a kincrome kit off them..: http://www.transquip.com.au/ |
Author: | Stuartminidlx [ Thu Sep 01, 2005 9:22 pm ] |
feeler gauges. gasket scraper. marking tools for when u pulling it down.(match marking things) |
Author: | doorlady [ Thu Sep 01, 2005 9:26 pm ] |
Primary gear oil seal tool . You do not want to damage that seal big job to get it all back in and find out you damaged it and pull it all back out. |
Author: | min13k [ Thu Sep 01, 2005 9:33 pm ] |
bfh to throw across the room when you drop a bolt inside the motor .... makka |
Author: | Harley [ Thu Sep 01, 2005 9:48 pm ] |
What size torque wrench would anyone recommend I get? Meaning, what torque rating over the maximum tightened part strength should I get? |
Author: | min13k [ Thu Sep 01, 2005 9:54 pm ] |
dunno what size but get a good one they start at around 300 makka |
Author: | drmini in aust [ Thu Sep 01, 2005 10:00 pm ] |
min13k wrote: dunno what size but get a good one they start at around 300
makka W&B still the best IMO, but I can't afford (I do have their baby 180in/lb one) ![]() If you must buy a cheapo one the dial & pointer ones are more believable than the cheap clicker ones. Eh, Aaron... ![]() |
Author: | Wolfman [ Thu Sep 01, 2005 10:26 pm ] |
Vernier calipers and a micrometer come in handy too. |
Author: | willy [ Thu Sep 01, 2005 10:31 pm ] |
Loctite. |
Author: | gafmo [ Thu Sep 01, 2005 11:02 pm ] |
Good set of Ring Openended spannes and Sockets Torco Engine Assembly Lube |
Author: | min13k [ Fri Sep 02, 2005 12:13 am ] |
oh and rachit ring spanners great for them tight places like the manifold nuts makka |
Author: | Lillee [ Fri Sep 02, 2005 9:20 am ] |
Die and Tap set to clean the head stud holes and other holes Valve spring compressor to put the new valve springs on your head if that's what your doing Feeler gauges Lots of WD40 That's all I could think of so far... |
Author: | Mike [ Fri Sep 02, 2005 3:45 pm ] |
Aviation gasket cement - but use sparingly (you could probably scrape enough of that crap from inside my engine to do 3 others). Loctite red threadlock (to replace the crumbling metal lockplates. Buy or arrange to borrow some large sockets for the harmonic balancer and the main bolt (1 5/16" methinks) Engine lifting brackets LOTS AND LOTS OF SMALL CONTAINERS OR ZIPLOCK BAGS TO STORE NUTS, BOLTS WASHERS ETC. AND CLEARLY LABEL EVERYTHING IN DETAIL - ESPECIALY IF YOURE GONNA BE DOING THE REBUILD OVER A LONG PERIOD. OTHERWISE YOURE DONE FOR IT - COZ YOU'LL PRETTY MUCH NEED TO STRIP ANOTHER ENGINE TO FIND STUFF YOU LOOSE. btw getting a cheapo buggered 998 scrap block is not a bad idea either, coz you could strip it for any bolts etc, you might need. Very useful. |
