It is currently Sun Jun 29, 2025 8:30 pm
 Post subject: Front Neg Camber arms
PostPosted: Thu Aug 25, 2005 7:21 pm
does anyone have a set of 1.5 degress neg camber arms because i am making my own and would like to no how much longer they are than standard ones.
PostPosted: Fri Aug 26, 2005 7:41 am
I hope you are not just cutting and welding them, it's illegal now.. :shock:
(Although I did it years ago, spaced them 1/8" and arc welded them up... we could get away with anything back then). :lol:
According to Vizard's book HTMYM p156, every 1/8" length change gives about 0.5* angle. I haven't checked by doing geometry lately, but I would have thought more. I doubt the 1.5* arms are 3/8" longer... :roll:
PostPosted: Fri Aug 26, 2005 7:44 pm
i was goin to cut and weld them. i thought they might be illegal but i'm not fussed with that because i am doin to a spare set. and who is goin to look anyway. i am runnin 6" wide welded steel wheels and only the guy who did my blue slip notice because he was a ex BMC mechanic.
PostPosted: Sat Aug 27, 2005 8:17 am
Cut and welded bottom arms (apart from being illegal) can be fine if they're done properly - I know of many who have used them for competition and road use for decades without drama.
I'm not sure what Vizard recommends, but if you start with 2 pairs, measure them carefully and cut through them at slightly different places on a 45 degree angle - you can then weld the longer sections from each pair together to avoid using a spacer. The arms are forged and there are special rods that should be used for this material, take them to a professional welder unless you are sure you know what you're doing.
Curly
PostPosted: Sat Aug 27, 2005 8:23 am
I definitely wouldn't try welding them with a small home MIG welder. You won't get good penetration....
PostPosted: Sat Aug 27, 2005 1:39 pm
i am goin to get it welded at work with a large mig welder. that is a very good idea using to parirs of arms. i went to mini spares padstow today and they are making a kit with ajustable tie rods and neg camber arms
PostPosted: Sat Aug 27, 2005 10:04 pm
Yep, and this is one of those situations where you really want 100% penetration. As well as no inclusions, porosity etc.
What are the off the shelf 1.5 deg. arms worth out of interest???
PostPosted: Sat Aug 27, 2005 10:08 pm
For a Pair of solid 1.5 neg arms they're ~$195-$225
PostPosted: Sun Aug 28, 2005 6:48 pm
where from
PostPosted: Sun Aug 28, 2005 8:42 pm
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=4568528321&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
MiniSport in Adelaide will list them for you i'm sure with a buy it now price..$195
Karcraft list them for $225 i think..double check that though, last time i checked even with shipping on top Minisport came out cheaper ;)
PostPosted: Mon Aug 29, 2005 12:32 am
A wise man keeps telling me..
"Dont get 1.5 degree fixed bottom arms you idiot!!"
Then he always says:
"Get adjustable ones so that you can start by correcting any misalignment before dialling in the 1.5 degrees."
Wise words :wink:
PostPosted: Mon Aug 29, 2005 8:10 am
But the adjustable ones are technically illegal for road use- whereas if you fit fixed 1.5s, nobody will ever know by looking... :P
PostPosted: Mon Aug 29, 2005 9:00 am
Is it not possible to get them engineered at all?
Chris
Everything I like is either
PostPosted: Mon Aug 29, 2005 9:12 am
I'd say you can get everything Engineered...
I'll be putting everything on Morrisand saying this this this this And this
sign it off please...here's $200 cash :wink:
PostPosted: Mon Aug 29, 2005 12:03 pm
Sure it is, my point is most people don't bother with that step, it costs $$$- and with fixed 1.5 arms nobody will pick it, even if the unthinkable happens and you bend it. :wink:
Users browsing this forum: No registered users and 18 guests
