It is currently Sun Jun 29, 2025 7:18 pm
PostPosted: Thu Aug 18, 2005 9:46 am
Thanks for all the help so far guys, I'm learning heaps.
I have narrowed down my rough running standard 1100 to a carby leakage in the throttle linkage.
I place my finger over the end and push the throttle linkage tight against the carby
and it idles and revs silky smooth!
I checked for this after remembering I had read someone's post last week, unfortunately I can't find that post now.
I think the suggested fix was; new carby, re-bushing, or I think someone mentioned machining the hole and replacing with a larger diameter shaft?
Some guidance would be much appreciated.
PostPosted: Thu Aug 18, 2005 10:12 am
When I had my car worked on last I was told I had the same issue.
I think he said there was a kit available to re bush it. It's probably only a one piece kit, but it would be cheaper than another carb.
PostPosted: Thu Aug 18, 2005 11:30 pm
The overhaul kit has new bushes and butterfly shaft - It will come up like new but you will need a vertical drill or lathe to get the holes plumb.
David L
PostPosted: Fri Aug 19, 2005 7:50 am
Yes you can also get an oversize shaft. Less hassle than fitting bushes. Often, the shaft wears more than the body does- measure both first. A new standard shaft may fix it.
