SU throttle linkage leak - How do I fix? https://ausmini.com/forums/viewtopic.php?f=5&t=10246 |
Author: | TimB [ Thu Aug 18, 2005 9:46 am ] |
Post subject: | SU throttle linkage leak - How do I fix? |
Thanks for all the help so far guys, I'm learning heaps. I have narrowed down my rough running standard 1100 to a carby leakage in the throttle linkage. I place my finger over the end and push the throttle linkage tight against the carby and it idles and revs silky smooth! I checked for this after remembering I had read someone's post last week, unfortunately I can't find that post now. I think the suggested fix was; new carby, re-bushing, or I think someone mentioned machining the hole and replacing with a larger diameter shaft? Some guidance would be much appreciated. |
Author: | Harley [ Thu Aug 18, 2005 10:12 am ] |
When I had my car worked on last I was told I had the same issue. I think he said there was a kit available to re bush it. It's probably only a one piece kit, but it would be cheaper than another carb. |
Author: | Wombat [ Thu Aug 18, 2005 11:30 pm ] |
The overhaul kit has new bushes and butterfly shaft - It will come up like new but you will need a vertical drill or lathe to get the holes plumb. |
Author: | drmini in aust [ Fri Aug 19, 2005 7:50 am ] |
Yes you can also get an oversize shaft. Less hassle than fitting bushes. Often, the shaft wears more than the body does- measure both first. A new standard shaft may fix it. |
