Stock 850 bolt on upgrades? https://ausmini.com/forums/viewtopic.php?f=5&t=102005 |
Author: | scotta_74 [ Wed Sep 13, 2023 8:21 pm ] |
Post subject: | Stock 850 bolt on upgrades? |
I have a stock standard 850 and am looking towards changing out to a newer 998 or 1100. Is there any worthwhile mods that can be done without major engine work to gain some extra horses on a standard 850? |
Author: | 1310/71 [ Sun Nov 05, 2023 11:22 am ] |
Post subject: | Re: Stock 850 bolt on upgrades? |
Find a big hill and go down instead of up? |
Author: | Steam [ Sun Nov 05, 2023 4:13 pm ] |
Most mods which are applicable to bigger engines will work on an 850 to some degree. David Vizard's books have good ideas. |
Author: | Mini Mad [ Tue Nov 07, 2023 9:25 am ] |
Maybe you can get the kids to push? ![]() |
Author: | andrew9 [ Tue Nov 07, 2023 10:45 am ] |
I have an 850 with a 202 head, but never got to test it out much because the primary leaked oil into the clutch and killed it. I've since moved on to 1098s. I wouldn't bother, make sure it is all perfectly tuned as stock and enjoy the period experience. |
Author: | i got a mini [ Thu Dec 14, 2023 9:19 pm ] |
Fit a 998 cc crank |
Author: | drmini in aust [ Sat Dec 16, 2023 8:28 am ] |
i got a mini wrote: Fit a 998 cc crank Won't fit without machining either the block, or the crank webs. Main bearings are wider on an 850. Back in the 60s I fitted several 1098 cranks and pistons into 850 blocks. Slight mods to the conrods. Put a 998 or 1098 motor (more torque) into it. ![]() |
