Fitting Mk1 Sliding Window doors on Mini K Shell https://ausmini.com/forums/viewtopic.php?f=5&t=101828 |
Author: | 69cooper [ Tue May 02, 2023 3:11 pm ] |
Post subject: | Fitting Mk1 Sliding Window doors on Mini K Shell |
Hi team , looking for some advise/tricks on fitment of sliding window doors on a Mini K shell , I am using correct seals obtained from Karcraft , but can't get the dam things to close correctly . No issue when I remove seals , with equal clearance between shell and doors , well as close as I could get it ![]() Thanks in advance Cheers Mal |
Author: | winabbey [ Tue May 02, 2023 4:58 pm ] |
Post subject: | Re: Fitting Mk1 Sliding Window doors on Mini K Shell |
Have a look at this long thread on door seals. In the link below I've fast-forwarded to the current area of interest which is remaking the original style. viewtopic.php?f=2&t=84464&start=75#p1068458 |
Author: | winabbey [ Tue May 02, 2023 5:00 pm ] |
The area around the lock mechanism on the B pillar is slightly different for sliding versus wind-up windows doors. Someone with knowledge may be able to comment. |
Author: | drmini in aust [ Sun May 07, 2023 11:20 am ] |
I brought 850 door seals in from UK and tried to use them on my 1970 matic, same shell as a K. Had a 3mm gap from door to body. Oz windup door rubbers are wider and fitted properly. You need proper 850 ones. |
