1275 crank damper choices https://ausmini.com/forums/viewtopic.php?f=5&t=101686 |
Author: | rednblackmini [ Mon Jan 30, 2023 10:44 am ] |
Post subject: | 1275 crank damper choices |
Hi, Have fresh 1275 stroked/bored out 40 thou = 1360cc - road/rally spec type engine - built more for torque than bhp. It will only be revved to 6k or more occasionally when driven. Is the cooper s damper ok or is an upgrade required ? What options do i have that are the physically same size as the standard damper ? Hint - forget med - I have their damper but because i want to run a Titan belt drive the med damper won't fit and I don't want to stump up again for their whole belt drive/ damper kit. Thanks |
Author: | awdmoke [ Tue Jan 31, 2023 1:23 pm ] |
Post subject: | Re: 1275 crank damper choices |
I fitted a lightweight Romac pulley but that was nearly 15 years ago: ![]() Still happy with it, very well made. Not sure if they even make them for minis any more, but you could contact them. |
Author: | GR [ Wed Feb 01, 2023 6:08 am ] |
HI Rednblackmini Give SU Midel a ring they have some new old stock MK 2 balance's i bought 2 of them if no luck give me a ring. Graham Russell 0296302195 |
