It is currently Sun Jun 29, 2025 8:39 am
PostPosted: Mon Aug 15, 2005 9:48 am
Anybody tell me ways of checking for blown head gasket or valve wear.
PostPosted: Mon Aug 15, 2005 10:01 am
you can grab a cheap engine compression gauge from supercheap and see if all cylinders have similar compression. Just take a plug out, stick it in and turn the motor over a couple of revolutions.
1974 Moke - 998cc
PostPosted: Mon Aug 15, 2005 10:11 am
Thanks!
Can you answer any of my other qestions? See recent posts.
PostPosted: Mon Aug 15, 2005 11:20 am
as said above or check for bubbles in the water when the engines running and check under your oil cap for whitish milky stuff
PostPosted: Mon Aug 15, 2005 11:41 am
There's no milky stuff anywhere just oil and water where it should be. I'll check for bubbles though.
My other questions are in seperate posts in the mini mod index.
I thought I was being smart by not putting too many questions in the one post.
