https://ausmini.com/forums/
Duplex vernier set up with 266S
https://ausmini.com/forums/viewtopic.php?f=5&t=101286
Author:  9er [ Sat Mar 26, 2022 5:31 pm ]
Post subject:  Duplex vernier set up with 266S
I was checking the camshaft timing after assembling the gears dot to dot, and even with the vernier adjustment I couldnt get to 106 degrees, it was more in the 125 deg range.
So I moved it one tooth away (from the dot to dot position) and was able to get it spot on.
Any comments welcome.
Author:  winabbey [ Mon Mar 28, 2022 1:33 pm ]
Post subject:  Re: Duplex vernier set up with 266S
I understand this is not uncommon, to be one tooth out. Great you sorted it.
Author:  9er [ Mon Apr 11, 2022 11:24 am ]
I did check it every possible way I could, as I always expect operator error to be the cause, but I think it is as I described.
Author:  1071 S [ Thu May 19, 2022 6:07 pm ]
On my vernier setup, one tooth off moves it well outside the venier range to correct....
Worth checking.
Cheers, Ian
Author:  FNQ [ Fri May 20, 2022 7:44 am ]
hi 9er
No idea whether that gear/ cam or chain looks misaligned, which is what i think you are asking for. I have read of a couple of instances where the setup was a bit of a 'guess' which side of the tooth the chain should go for the dots to be aligned..... but no memories of any particular cam or gear etc..... so a good reminder to dial in the cam even if it is just as a confirmation. The other part of your situation also fits the bill. IIRC one tooth on the timing gear is worth 18 degrees( which for those without a vernier setup correlates to offset keys being available to 9 degrees), so your 125 degrees minus one tooth puts you very close to 106 ( and certainly then adjustable at the vernier)
