Joined: Sat Mar 24, 2012 1:39 pm Posts: 583 Location: qld
hi 9er
No idea whether that gear/ cam or chain looks misaligned, which is what i think you are asking for. I have read of a couple of instances where the setup was a bit of a 'guess' which side of the tooth the chain should go for the dots to be aligned..... but no memories of any particular cam or gear etc..... so a good reminder to dial in the cam even if it is just as a confirmation. The other part of your situation also fits the bill. IIRC one tooth on the timing gear is worth 18 degrees( which for those without a vernier setup correlates to offset keys being available to 9 degrees), so your 125 degrees minus one tooth puts you very close to 106 ( and certainly then adjustable at the vernier)
