It is currently Mon Jun 30, 2025 9:16 pm
Post new topic Reply to topic  [ 79 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
PostPosted: Mon Oct 03, 2005 6:57 am
As said the idle jet size also controls the fuel mixture above idle for a fair way.
Idle jet size should be selected to get it running clean just above idle without an acceleration flatspot. If the idle screws need to be screwed a long way out the jet is too small, as feral said..
Fer example, in my case (Dellorto 45 on a 1310, then 1360) I ran it for years (34mm chokes) with 50 idle jets, but when I went up to 36 and then 38mm chokes I had to upsize the idles to 55s. :wink:
Check what emulsion tubes are in it, but if it was OK before they are probably right. Usuals on a Weber for a Mini are F2, or maybe F16.
PostPosted: Thu Oct 06, 2005 1:46 pm
thanks doc, I had a play with the jets today, half a turn makes quite a bit of difference. Im still playing, each time I go for a drive I wind em out half a turn and see how that goes :)
If I leave it as it is it seems to be running fine I just have to keep it above about 2500 revs ;) That would be ok on the track but the neighbours might get a bit antsy with me tearing up the street in my optimum rev range :) I'll try different setting and then swap jets if necessary. thanks guys :)
78 van 1300 cam extractors weber, 12" Superlights Metros Konis HiLos MP3 Amp Sub Alpine speakers and lots of fur
www.crazybitchracing.com
PostPosted: Thu Oct 06, 2005 7:51 pm
My neighbours dont seem to mind when i do 4000rpm out of down our street at 7:20. the kids at the bus stop love it though
If only milk and orange juice is meant to come in 2 litres, only cheap wine comes in 5 litres...
http://www.flickr.com/photos/13922833@N04/
PostPosted: Fri Oct 07, 2005 1:58 am
yeah the kids all love it. I drive past a school too. but the grown-ups frown at hoon behavior :roll:
