It is currently Sun Jun 29, 2025 1:12 pm
Post new topic Reply to topic  [ 74 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Wed Jul 20, 2005 7:17 am
ok guys whats the chances of getting some measurements? im willing to fess up some cash...
i really want some drilled and slotted rotors, i can get them cheap through work no worries, but im not to fussed on spending $500+ on metro stuff..
(ill need measurements for disc hubs) if possible.. anyone?? :)
GTi Turbo'd mini, abused daily
PostPosted: Wed Jul 20, 2005 6:08 pm
do you know the measurements of 12' rims? the inside of the rim?
I will be drawing up a cad file for the adapter plates soon
PostPosted: Wed Jul 20, 2005 6:40 pm
yeah i just got 13's so no worries there.. yeah just the caliper mounting brackets..
and maybe some info on what i have to do with mounting the flange and the rotor??
cheers 8)
 Post subject: Volvo Calipers
PostPosted: Thu Jul 21, 2005 9:30 am
13SEC
Yes you can get volvo calipers to fit the mini hub.
My setup used the 4pot volvo calipers with starrion vented disks and drum hub 1/4" spacer and the piping is a bitch.
Problem is you need 13" wheels that allow lateral clearance for the caliper for which I found only one brand and the setup weight of the whole lot is an absolute ton. Also the whole setup is held by 3 pissy bolts onto the drum knuckle (like most hybrid brake setups)
For 10" I run a mitsu caliper and a 8.3" dia vented disk
For 12" I get the feeling that Camira setup would be more then adequate (I have a set sitting in the garage ready for "Besser")
PostPosted: Thu Jul 21, 2005 6:04 pm
Besser - can you post more info about your 10" brake conversion?
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
PostPosted: Thu Jul 21, 2005 6:07 pm
For 10" I run a mitsu caliper and a 8.3" dia vented disk ???
pics info please :)
PostPosted: Thu Jul 21, 2005 8:33 pm
to increase the strength of your braking system, so that it is not relying on those pissy bolts, make up a little plate that sits on top and bolts to the steering arm,, and weld it to the backing plate. make sure the bolts are tight before you do so. Problem is to remove your steering arms you may need to undo your backing plate if it is too tight.
PostPosted: Thu Jul 21, 2005 8:40 pm
The standard 3 bolt fixing is pretty strong, the hub is tapped 5/16" UNF. The bolts just look weaker than they are due to the small hex heads.
Even a drum brake system can lock the front wheels without shearing things off. But for the Hondas Civics & Citys I did, I fitted Grade 8 bolts... :wink:
PostPosted: Thu Jul 21, 2005 10:19 pm
Ben I dont think the mitsu conversion will fit with your mamba wheels. The Contessa tapers down closer to the centre line of the rim compared to the mamba and this is a critical dimension when clearance is down to 1.5mm
You know the R&D is half the fun and all the cost, so maybe you could find a setup for your Mambas
Sorry about the 8.3" it's mor like 210mm and yes it fits.
PostPosted: Fri Jul 22, 2005 12:08 pm
i have contessas :)
PostPosted: Fri Jul 22, 2005 4:59 pm
i have mambas :(.
besser - what calipers do you use for that 10" conversion?
 Post subject: good question
PostPosted: Fri Jul 22, 2005 11:10 pm
single pot mitsubishi, Ill get the number off them for you.
PostPosted: Sat Jul 23, 2005 1:17 pm
thanks for that, do you know what model they come off?
 Post subject: nothing Local
PostPosted: Sun Jul 24, 2005 11:10 pm
Havent seen them on anything I have found locally. I have taken to making my own backing plate even though the original was almost perfect.
