It is currently Fri Jul 18, 2025 2:51 am
Post new topic Reply to topic  [ 119 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Tue Nov 14, 2006 10:22 pm
My 1330 revs to 6500. But doesn't make much more power than 6000, when I did a hillclimb I looked down at the tacho, becoz with the helmet on I couldn't hear much i saw it peaking at just below 7000, so that's when i shifted into 3rd gear! But seriously 4000 is cruising rpm. An 1100 won't rev as high as my 1330. But 4 grand won't hurt her. I wouldn't complain about cruising at 5 grand in my car. I wouldn't want to do long periods any higher tho.
PostPosted: Wed Nov 15, 2006 7:50 am
My 1152 will rev over 7500 if you take it there. Don't talk crap.
In between 4-5k is better for your engine apparently Sean than 3.5 and lower as the engine harmonics are worse.
PostPosted: Wed Nov 15, 2006 8:49 am
yeah wtf my 1132 will easily see 7000 with a standard carb+inlet/exhaust 8)
i agree about the harmonics, but it depends what size motor you have
PostPosted: Wed Nov 15, 2006 2:25 pm
My Red Mini with 1100 often saw 7500, especially in the school carpark for some reason (ask Lisa Mini Mad) :oops:
Daniel
PostPosted: Wed Nov 15, 2006 3:05 pm
Haha i will, showing off to the girls? :lol:
PostPosted: Wed Nov 15, 2006 4:00 pm
7000+ from an 1100 is crazy! Not stock ay? 8) I've been in people's 1100 Mini K's and mokes and they max at about 5500. They were stock and seemed to run nice. Ryan, your 1132 is not an '1100' I meant normal stock engines, that engine ain't stock! Im sure if my engine wasn't stock it would rev that high also. Also aren't a bit worried at that rpm? I got EN40B crank, double timing chain etc. 1100s don't have any of that nice stuff.
PostPosted: Wed Nov 15, 2006 4:27 pm
It's all dependant on cam. If you have a stock cam then yes they were designed to max out about 5500rpm. If you have a race cam then they don't make power until 3500 or 4000rpm!
Big bores don't rev as hard as 998's with their short strokes so don't knock the small bores!! :wink:
PostPosted: Wed Nov 15, 2006 4:37 pm
Size has nothing to do with it! are you saying that a 500cc bike engine can't rev as hard as a 6L V8???
It's all setup: cam, valve lift, spring rates, where the engine revs to is where the power starts to drop off, ie. where the volume of air and fuel flow reaches it's maximum, or your valves start to bounce, or your crank is falling to pieces...
PostPosted: Wed Nov 15, 2006 4:41 pm
Standard redline for a Cooper S as per the marks on the speedo is 6800 rpm and many a race mini will see 8500 rpm :D ask Grieg, takes a lot of work, GR destrokes and overbores the really good J cars to stay under 1300, have known of a couple of big bore shrort stokers to see around 10,000 was one that lived in Brissy that had all the good bits, Allen crank and special rods and the like used to see 9500 all the time :D
Jon
PostPosted: Wed Nov 15, 2006 6:50 pm
1098s properly prepped will take a rev, ask any Sprite racer... :wink:
Vizard says they will stand 8K for a while.
My 1220 Mini back in 1968 used to see 8500 often, and it lasted 20,000 miles of abuse. crank was a new 1098, balanced and shot peened.
It wasn't the crank that stopped it, but the circlips in the (*%$^ Imp pistons. :cry:
PostPosted: Wed Nov 15, 2006 6:56 pm
meenis stock and has been up and over 6500 :D but i wouldnt recomend more then a second at that much before one of the pistons shoots throught the bonnet..
Potato
PostPosted: Wed Nov 15, 2006 8:13 pm
my 1100 has a duplex timing chain, its built properly and balanced, so i have no worries at all about revving it
what you are saying is, the cooper "S" motors were built to race, the smallbore motors were not.
PostPosted: Wed Nov 15, 2006 8:21 pm
I'm pretty sure mine had a 731 cam, this was stock-ish, and the head was a 12G295 unported with twin jugs on it.
The engine didn't seem to worried about high revs, but the dynamo didn't like it and sent brass filings all through my engine bay one day.
Stock engines probably cam and valve springs would limit rpm capability I spose, I don't know as I've never owned a mini unmodified in the engine dept.
Daniel
PostPosted: Wed Nov 15, 2006 8:27 pm
The first things that will stop an engine from revving high are valve springs and ignition points.
The reason that a lot of people can get their engines to rev over 6000rpm without problems is probably due to Smiths tachos.
PostPosted: Wed Nov 15, 2006 8:28 pm
No, please don't tell me what I was saying as I know what i said. I wasn't having a go at small bore drivers, just that your 1100 ain't standard I was refering to stock engines, i should have made that more clear. I was actaully talking to someone else when i said that. But you decided I was having a go at you. And of course, you car is built up to be a solid performer, but were 1100's from factory? I don't think so, they drive nicely but are be no means race engines. I actaully don't believe the 'S' is a 'racing' engine just built tougher than all the other motors.
Users browsing this forum: No registered users and 23 guests
