It is currently Sat Jun 28, 2025 12:37 am
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Thu Jun 16, 2011 9:06 pm
Yes Ive been following your guide however my block doesn't seem to have any deeper recess for the oil pump than any of the small bore blocks I have, Its most defiantly an auto block however.
PostPosted: Thu Jun 16, 2011 9:33 pm
The 1100S automatic block has the same depth recess as a smallbore, it is NOT any deeper.
However..
The oil feed drilling from the oilpump to the relief valve and banjo fitting is closer to the rear of the block on all 1275s than on a smallbore, to miss the bigger diameter cylinder bore. This is why in the auto block an oil pump spacer is needed, and why the drilling breaks into the back of the spacer (see my pics).
All 1275 manual blocks have a shallower pump recess, and their oil pumps had a longer shaft.
Here's what happened when someone tried to do it without any spacer-
http://members.tripod.com/austin_americ ... kdepth.jpg
PostPosted: Thu Jun 16, 2011 10:32 pm
Thanks, That makes sense now, Mustn't have been reading it properly.
PostPosted: Mon May 07, 2012 10:42 pm
someones done one a long time ago on an 850. Rat rod 850 8)
http://www.lojomo.com/
Users browsing this forum: No registered users and 29 guests
