It is currently Mon Jul 07, 2025 3:44 pm
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Sat Sep 01, 2007 6:08 pm
im running a holley blue electric pump and the the holley fuel regulator which has been modified for boost so that its rising rate.
this worked great with 6psi boost as was easy setup, cause you can use std line without the return. But as the pump is only 14psi pressure , and fuel pressure has to be 3-4psi above boost at all times this limits the boost to 10psi.
i think james (kazjim) modified his pump for more pressure but not sure how.
so in theory should work at 10psi , but was not flowing enough fuel at drags for the full 400m and the engine was emptying carb befor pump could fill it at 10psi.
so what im doing now, tank is replaced with injection tank (injection pump is 2bar i believe so plenty pressure) and malpassi regulator as that has fiting for return line. will be adding 8mm return line and feed line will be upped to 8mm to.
PostPosted: Sat Sep 01, 2007 6:45 pm
thats how my turbo is fueled, works great. the SPi pump has 2.7 bar, the MPi nearly 4bar, but not sure about the volume. but its reasonably easy to fit an other in-tank pump if thats not enough
Rover 214 atm ....
PostPosted: Thu Sep 13, 2007 8:32 pm
G'day
Great work man, it looks great. I sure it goes like a cut snake.
I was just wondering where you got the megajolt system from ?
PostPosted: Fri Sep 14, 2007 9:45 am
you can buy them off ebay http://cgi.ebay.com.au/EDIS-6-Module-suit-MegaSquirt-Megajolt-application_W0QQitemZ190152095914QQihZ009QQcategoryZ102349QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
PostPosted: Fri Sep 14, 2007 2:16 pm
hi ben,
just wondering where you sourced your spi tank from?
im going to do the setup in a van would it be easier to get the existing tank modded to run a return?
and also which type of 5.125" trigger wheel did you buy from trigger-wheels.com was it the ring gear type (and then you drilled holes into the pulley and mounted) or was it the trigger wheel with the 1/2 pilot hole
thanks
PostPosted: Fri Sep 14, 2007 7:36 pm
thomen wrote:
hi ben,
thanks
His trigger wheel was the ring gear type, I machined the harmonic balancer to suit.
PostPosted: Fri Sep 14, 2007 10:32 pm
awesome! so doc if i was to do something similar could i employ your services to do the same?
PostPosted: Fri Sep 14, 2007 11:13 pm
No worries. :wink:
