Babes wrote:
Also my MAP sensor is off the supercharger manifold and i will be getting a bespoke fuel rail made, whats the best option with throttle body? I was going to just use the carb bottom as a throttle body and have a blanking plate made for the top of it. Maybe Im getting too full on and there is an existing bolt in throttle body I can use?
using a carb with a plate on the top will be a compromised solution as you'll always have disturbed airflow from the centre bit, and there isn't anywhere convenient to mount the throttle position sensor.
I'm using an N14 pulsar throttle body, and so is the guy doing the turbo in the gallery forum. Its a neat unit, return spring is mounted on one end of the shaft, and throttle position sensor is mounted at the other end. It's wide but short so nothing will poke upwards through your bonnet.
Im guessing I will be putting out 130-150 bhp at the flywheel so will need to research injectors.
Guess more towards the 150+ range - michaelb made nearly 100 at the wheels from his with (what looked like to me) the mixture leaning off at less than 6000rpm. He's probably watching this thread with a lot of interest actually. Particularly the part where you mounted the carb somewhere sensible and went for a drive - that long pipe is just ridiculous
Two 550 to 600cc injectors should cover it, but as I said previously, my 440cc injectors are running almost to the point where they're being turned off before they're being turned on. I plan to play on the dyno tomorrow with staging and hopefully my mate has ordered in some 550's for me to replace the 440's I have in there now. I guess I'll update my build thread in mini mods with some of the results
If I was building my manifold again, I'd try to use Bosch EV14 style injectors. They seem to be the most readily available, everyone seems to be moving towards the same style, and would be the easiest to mount in a tight space.
Injector size calculator -
http://www.smartfireinjectors.com/ebay/ ... chart.html
did I tell you that I won a
trophy?
