69k1100 wrote:
Is 4140 the right material though, definitely cheaper but my limited understanding tells me that it is harder to properly heat treat? And has less tensile strength?
Yeah it's fine, 4340 is slightly better, it has a slightly higher tensile rating as I mentioned earlier, as well as a better Yeild, and its other mechanical properties are generally a little better suited, but 4140 is still fine.
You'll notice for example the UTS ratings "range" from 850 - 1000MPa for 4140, and ""Range"" for 4340 is from 930-1080MPa. Those numbers are averages based on random sampling.... So the numerical average UTS for 4140 is 920MPa and the numerical average for 4340 is 1005MPa.... you're looking at bugger all difference there. And often you might pick up 4140 that sits above the bottom of the range for 4340 and at the same time 4340 thats lower than the upper range for 4140. Does that make sense? And as far as annealed hardness goes, 4340 is slightly higher.... you're looking at 248 - 302HB for 4340 and 223-277HB for 4140 (if you want that in the Rockwell C scale... 20HRc to 28.8HRc for 4140.... v's... 24.2 - 32.1 for 4340)... That said most places supply 4340 as hardened and tempered... but only barely
you can still machine it very easily. Interlloy quote 28-36HRc for their 4340.
As far as hardenability goes they're much the same. Neither is any easier or harder to harden.. They're both water or oil hardening (water if you want it harder though).. both can be nitrided, though 4340 needs longer immersion because of the high nickel content.
But there isn't a huuuuuuuge difference between them. Certainly not enough to worry about.
