bnicho wrote:
Daihatsu Handi(?) 7" disk callipers wold probably fit but the disk design is again not suitable, so you would probably have to use disks from something else anyway. But as teh Doc says, the pads are really small - they are designed to stop an 600-800cc car with 30hp power, not a Mini with a 70-130hp 1275!
as far as the metro 4 pots go, I couldnt find a straight replacement pad, so I used a set for a Mercedes light commercial. The pad was bigger in width and height, locator/pin holes matched pretty well, I got them machined down so that they JUST fitted in the caliper, which means greater pad/rotor contact than the old pad, whatever it was
