It is currently Sun Jun 22, 2025 12:25 am
Post new topic Reply to topic  [ 377 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18, 19 ... 26  Next
PostPosted: Mon Mar 21, 2005 8:17 pm
Stick a pencil down the bore..
Then, take the rocker cover off, check the valves on #1 and #4. You want the 2 valves on #4 to be tight, that means its TDC firing on #1.
If valves on #1 are tight, turn the motor over 1 full turn. :wink:
PostPosted: Tue Mar 29, 2005 7:15 pm
kazjim wrote:
"I set them so they don't quite kick back (much!) on starting."
mine is now timed for Max Power and Minimum detonation (actually NONE!!)
J
How do I know if it is set for Max Power?
PostPosted: Tue Mar 29, 2005 7:36 pm
Keep advancing the timing a little at a time, and check how it goes. If motor gets rough, or pings, or kicks back badly on starting you have gone too far.
You need a strobe timing light to do this properly. I set mine at the maximum advance point by revving it to 4000+ (no vac advance used) and check wher it is. Most A series like around 30-34* full advance. I won't tell you what mine likes, but it's more... :shock:
I have marked my harmonic balancer pulley and the timing cover- it's easier than peering into the flywheel access hole. :lol:
PostPosted: Wed Mar 30, 2005 2:45 pm
Thanks for that, will have a go this weekend.
Pete
PostPosted: Sun Apr 10, 2005 2:55 pm
i put the dissy in with the rotor pointing to the general direction of piston 1 the rotor is facing the number one lead on the cap too. when i try and start it i get nothing but when i accelerate aswell my carbies pop what is wrong? the blue wire is on the -ve and black to +ve it is a d4r83 too help
PostPosted: Sun Apr 10, 2005 3:20 pm
Take off the rocker cover and check that when the rotor points to #1, it is about TDC and both #4's valves have zero clearance.
If you get it started but it won't rev, it is way retarded- turn dizzy clockwise a bit.
You will need a strobe timing light to time it properly. :wink:
PostPosted: Sun Apr 10, 2005 4:21 pm
its all good had been at top dead centre on exhust instead of inlet got it going runs great and idles lovely and starts sooo soo easy thanks for all the help
:D :D :D :D
 Post subject: dizzy wiring
PostPosted: Fri Apr 15, 2005 11:24 pm
when hooking up the coil with the pulsar distributor is the - terminal of the coil grounded or does that happen thru the dustributors electronics
 Post subject: Re: dizzy wiring
PostPosted: Sat Apr 16, 2005 7:10 am
Just uses the 2 wires from the dizzy. Blue is <-> . Ditch the little suppression condenser if still there, you don't need it.
PostPosted: Sun Aug 07, 2005 8:09 pm
NOTE: fit it so the rotor's brass strip is pointing at 1 o'clock, and the `drive key' is below centre of Mini drive dog.
Okies, any pictures of this? I'm not sure which way I fitted mine, will this cause problems?. Also, can someone get me a diagram to show the leads (which is 1,2,3 & 4). My leads are marked, but no idea if they go 1.2.3.4. along the block or 1.3.4.2 like the Mini's firing order.
PostPosted: Sun Aug 07, 2005 8:14 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
like the mini fireing order that will not change
makka
PostPosted: Sun Aug 07, 2005 8:32 pm
OK, but what about the drive dog? What will that effect if I have it 180* out? Will that mean I just need to rotate the engine 180*??
PostPosted: Sun Aug 07, 2005 8:38 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
turn the rotor 180deg
so it is pointing op way
if ya know what i mean
makka
PostPosted: Sun Aug 07, 2005 8:58 pm
Not sure what you mean. Remove pin and rotate then reinsert pin? Or just take dissy out, then rotate the dissy shaft 180? If the latter, won't that not fit because one side it larger, the drive pin thingy is offset??
PostPosted: Sun Aug 07, 2005 9:00 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
well move the plugs on two positions each :)
makka
Users browsing this forum: Google [Bot] and 36 guests
