It is currently Sun Jun 29, 2025 11:50 pm
PostPosted: Mon Aug 15, 2005 7:54 am
Chris wrote:
Stuwey_LS wrote:
I want to try a late model Honda Civic one on the the drivers side, they are much smaller, and with Alloy core, work much more efficiently.
Don't you believe it. Copper is far and away better than any aluminium radiator. It is heavier than aluminium, but works better.
And unlike copper, aluminium corrodes badly inside with age which further stuffs up the heat transfer.
Most Ford taxis here in Sydney fling the crap alloy 2 core rad and fit a copper/brass 3 core. Way better.... I had one in my tow car.
Car makers went to alloy rad cores with plastic tanks for 1 reason only, to save $$$. :evil:
PostPosted: Mon Aug 15, 2005 8:56 am
I thought that copper rad's are better at getting the heat out of the water, but alu rads are better at radiatiing the heat away? Either way i dont think you would notice the difference between the two if they were both well designed and suited to the car.
Would make sense why a lot of heatsinks have alu fins with a copper slug pressed into the middle.
Mini - The Wizardry on Wheels!
PostPosted: Mon Aug 15, 2005 8:57 am
Copper is just a far better conductor, heat or electricity. End story... :wink:
PostPosted: Mon Aug 15, 2005 9:33 pm
Provided the radiator is capable of cooling the car in all conditions you would be correct, but size for size copper will always transfer more heat than aluminium. Aluminium is used to reduce weight. Copper radiators are heavy and expensive to manufacture.
Chris
Everything I like is either
