It is currently Mon Jul 07, 2025 5:57 pm
Post new topic Reply to topic  [ 77 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sat Jun 25, 2011 5:38 pm
I see then if it won't stick out and look ugly, how much to build a 200+hp twin cam turbo engine (including all machining)
PostPosted: Sat Jun 25, 2011 6:47 pm
Are you going to build it your self or pay some one to do it?
PostPosted: Sat Jun 25, 2011 8:07 pm
Meeni, have a look at this list TheMiniMan posted about building his 1litre NA motor:
TheMiniMan wrote:
& if you would like to add up it`s replacement value, then here you go-->
2nd hand 8V head--> $500
The conversion kit -->$1500
sleaves & fitting, rebore to .o8o", supply & mods to pistons (flycuts for valve reliefs) mods to block & head to make it all work -->$1500
oil pump, water pumps & engine bearings & thrusts & gaskets & seals & a couple of syncros & gearbox bearings & leyshaft, new clutch, cleaned out & modified radiator etc etc etc the list of fiddly things goes on & on, such as the oil filler & engine breathers & oil drains & oil feed hose to the cyl head , mini cam lobes ground off, etc etc etc ---> well over $1000, (more like $1500)
Power unit build labour cost would be at least -->$1000
Special Head gasket made to suit from Qld gaskets-->$220
Quad 40mm Bike carbs--> $300-$400
Manifolds to suit carbs--> over $100
Ram tubes from another bike, modified & fitted---> at least $100
New 4-into-1 Extractors $450
Dyno tune cost me --> $250 (& that was cheap), but could do with another now after fitting the ram tubes... & wouldn`t take long to fine tune it now, barely even needs playing with at all now it`s running so nice really but i`d still give it a bit more of a tickle to sweeten it even more
soooo,,, there you go,,, added up it`s way over $7000 worth & that`s not including the price of the entire power unit to start with.
Ad on top of that a gear box rebuild, the turbo, turbo manifold work, ecu, bigger bike head..
And you have a very expensive motor..
You're so square
Baby I don't care
PostPosted: Sat Jun 25, 2011 9:48 pm
id put it together myself id say, cept maybe the gearbox i hate those..
yeah thats pretty dear, well not really but still 10 grand can go a long way elsewhere in life (half a race weekend :P )
i just dont want to build something and go.. oh, is that it.. which is currently what the mild 1275 feels lik :roll:
PostPosted: Sun Jun 26, 2011 9:41 am
hee hee,,, yeah it costs about $20K for me to build you a complete turbo injected twin cam 1275cc or bigger power-unit package , inc gearbox/diff etc
but they certainly won`t make you say "Is that it"... more like Holy Faaarrrrkkkk what have i created!!!!!!!!!!!!!!
but, yet again, they are so smooth & drivable that anyone who hops into the car will have absolutely no idea that there is 200hp,,,, until you apply a little more pressure with the right foot,,, then Hang On :-)
John & Simon from Specialist Components in England have finally pushed past the 300hp mark now :-) & more people are following the same standard with these turbo twinkys shortly
we`re happy with our 167hp for road use tho,,, not much point for any more than that really,,, & yet if you want more--> then a simple switch to program #2 & you have way more boost with a tune program (fuel & injection maps) to suit & 200hp is on-tap
But,,, i must admit that if you just wanted a cheap, fast, easy option, then bung a lung onto a mini 5-port & you will have fast, cheap, easy power... just not as sophisticated or civilized,,, that`s all.
to me,,, insane, broad spread, usable, smooth power with"""Stealth""" is the way to go :-)
but that`s just me :-)
PostPosted: Mon Jun 27, 2011 4:21 pm
ausmini mod
ausmini mod
Mine is over the clutch and all is well.
A few in the UK too... the manifold that Ben makes sits behind the engine, a T2 would fit with room around it too.
I honestly think a T2 is too small on a 1300 though... imho.
It all adds up quick though.
Peter
PostPosted: Mon Jun 27, 2011 5:42 pm
Peter
I agree,
PostPosted: Mon Jun 27, 2011 6:05 pm
T2 is a bit small for what I want.. What's the gt25 or something that the uk guys are talking about? I don't have 20 grand matt sorry.. I'm happy to pay for quality bits for the motor but I can't pay squillions for labour so il build it myself, and knowing many have built 5 porters with good power and life I think that's the go, it's also more familiar to me..
PostPosted: Mon Jun 27, 2011 8:50 pm
we have run a few different ones, but the GT2560 is a pretty sweet item
PostPosted: Mon Jun 27, 2011 9:59 pm
Supercharged
would you consider a 4efte or similar engine transplant?
PostPosted: Mon Jun 27, 2011 10:08 pm
no, want it to stay a series
PostPosted: Mon Jun 27, 2011 10:16 pm
Supercharged
what kind of budget did you have in mind?
PostPosted: Mon Jun 27, 2011 10:26 pm
as i said i wanna build the parts up over the next few months so not overly fussed, just not 20 grand :lol: i cant know what im going to be paying without knowing what i have to buy
PostPosted: Mon Jun 27, 2011 10:29 pm
No, you cannot know what you will pay
But you can know a potential limit.
So currently we can assume your budget is up to $19, 999
With that information I would suggest you ask Matt Reid to build you a turbo twinky, and you'll owe him $1.
A ball park figure would go a long way in helping people suss out your options.
Be crazy, take a stab at what you think you can spare for the build.
You're so square
Baby I don't care
PostPosted: Mon Jun 27, 2011 11:30 pm
Meeni, if you want to stay 5-port, then buy some quality valves & get GR to do you a nice head, then add one of his RE13T cams,,, chuck a GT2560 onto a custom manifold & with a bit of a hunt around the UK you should be able to pick up a turbo carb & manifold (i think i have a turbo inlet manifold here)
then bob`s your Aunty
make sure your gearbox is up-to-par
slip in a slippery diff
& away you go
it really don`t matter what size the bore is, i`d keep it fairly small tho, to keep rigidity & integrity in the bore walls
& obviously overhaul everything inside the thing, oil pump, lifters, crank & bearings, make sure you have some good con-rods, & make sure all your clearances are a little on the larger side & you`ll be fine
probably $10K-ish will suffice (((if you allready have the 1275 power unit to start with))))
& yes my Turbo Injected twinkys are not cheap, but as with anything you buy-->you get what you pay for
it`s all about having some fun in your brick hey???
& just so everyone is quite clear with me on this--> i`m not pushing my twinkys on anyone really,,, i`m way too busy building 8 of them at the moment so i couldn`t take another one on for another 3 or 4 years anyways
