It is currently Mon Jul 07, 2025 3:47 am
PostPosted: Fri Jun 15, 2007 9:12 pm
If getting this one, http://www.minispares.com/Product.aspx?pid=34684
I doubt it will flow any better than a Redline 3005 , and it's heaps dearer. Although that does include the linkage.
Ballpark figure for a Redline 12-3005 NEW is around $170 I think.
see http://www.redlineauto.com.au/
:wink:
PostPosted: Fri Jun 15, 2007 9:45 pm
Thanks for that, a friend was going to the UK and was going to bring it back which would have saved $100- but they are out of stock anyway. On top of that Minisport weren't able to give me a definitive answer as to wether they fit woithout cutting the firewall so I will get a redline. Then I just need to work out which air filter to get. K&N / Ramflo / sock or other??? Then do I attempt to put it on or wait and save up for a new exhaust system? Thanks for all your help. Jim.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Fri Jun 15, 2007 9:57 pm
In a Mini with no Weber box cut into the firewall, there's precious little room for anything BUT a Ramflo. And that needs to be the offset type (case is offset upwards).
I'd bin the original foam in it, a Unifilter LNX400 pad ($8.95) has much less flow restriction and doesn't fall apart with age. :wink:
PostPosted: Sat Jun 16, 2007 9:33 am
I know I've been a pain but I'd rather ask questions than buy the wrong thing. You have been a very big help Dr Mini, thanks yet again. I think I have it sorted now! Cheers.
Member: VMCI #2474
