Stuartminidlx wrote:
right you are 1071 i have just set my car up now and i'm testing a few things but caster is one of those things were you can never have to much. it does weight the steering up abit but it's a mini not a dodge truck. i have a slight problem though because the car is low and i have large offset 10inch wheels i get abit of scrub so i'm goin to raise the car and cut the gaurds when i get it painted. the specs are now
Front
2* neg camber
2* foward caster
1* total toe in
Rear
2* neg camber
0* toe
i'm running rubber cones in a wet subframe with spax ajustable shocks
after i cut the gaurds i'm goin to try for around 6* forward caster.
You might wish to re-think the toe settings. You do not want toe-in on the front of a Mini.
As for your claim that you can never have too much castor, you can reach a point where you start to lose grip because of it.
Why so much camber on the rear? A Mini is an understeering car and adding more camber to the rear may increase the understeer.
My car runs 0.5° pos camber on the rear with a touch of toe out on the rear as well. You would not want these settings on the road in a Mini though.
But I suppose if everthing is adjustable you might as well try everything because you just might find something you like.
