Wondering about any advice on the engine I have.
I have a 1275 40thou oversized pistons with a double row timing chain. Currently fitted with Isky cam followers and Kent 286 cam. Running a 45 Dellorto and GR inlet manifold, Ultralight flywheel and Aldon Electronic Dizzy. The head is being built now with 1.401 dia inlet and 1.219 dia exhaust valves, with new guides and valve seats. New springs are being fitted that are replacing the 200LB dual springs that were on the head. I am wondering about advice on rockers, springs and any other advice before I bolt the head back on? The rockers are standard at present. Also any modifications or specific adjustments recommended would be helpful? Thanks
_________________ 1975 1310cc Street Mini Custom 1974 Leyland Mini daily driver 2008 Cooper S R55 Clubman
