benjamin wrote:
is it megajolt v3 or v4?
either way you can purchase a conversion kit.
http://www.autosportlabs.com/-c-1_21_28.htmlMJLJ V3 MAP conversion kit $24.95
MJLJ V4 MAP conversion kit $22.95
V4. Thanks for the information. I'm not sure I would be able to do this. How hard are these kits to install?
Could I wire an external map sensor to the Megajolt like a tps?[/quote
im not sure with wiring in an external map sensor but i dont see why its not posible, depending on sensor.
im again not sure on installing as i purchased mine completed, best to sign up to the autosports labs forum they are very helpful.
http://www.autosportlabs.org/index.phpEDIT > just found this>>you can do that with the TPS ECU using an external MAP sensor and connect that up to the TPS pins. Since both TPS and MAP sensors give a 0-5V output it all works fine, just remember to change the configurator to match your new setup.
