mini13 wrote:
on some of the VNT's they have a pressure actuator (most are vacum fed) as the pressure goes up the vanes open in a fairly linear fashion, sou you'll see somthing like a few PSI low down, building as the revs rise, you can then use an electronic boost controller or ECU to bleed the boost to what you want,
However what I'm looking at doing next is using an RC servo to control the vane position, the servo will be controlled by my megasquirt, and will have the benift of being able to open the vanes at cruise.
You can get a bosch solenoid/electronic valve that sends a signal to the MJ - was going to do that to my setup before EFI... based on certain things you set it (RPM etc) and it should do what you want.
