It is currently Fri Jun 27, 2025 6:22 am
 Post subject: Holley Carbies
PostPosted: Tue Mar 01, 2005 1:27 pm
I was looking around the web and noticed that you can get 350CFM twin barrel Holleys. Has anything ever been attempted with Holley Carbies as a replacement to the dellorto/SU etc. Probably not just wondered...
Matt
PostPosted: Tue Mar 01, 2005 3:47 pm
Hi Ministar,
beside the fact that you would probably have to fabricate your own manifold I think a 350 would be too big for a mini.
I had one on my 202 HQ Kingswood and it was the perfect carb.
The standard calculation for CFM carbies is
Engine size (CID) x maximum RPM / 3456 = CFM
CFM @ 100% volumetric efficiency
Where CID = CC / 16.39
Therefore for a 1275
78 X 6500 / 3456 = 147
PostPosted: Tue Mar 01, 2005 3:59 pm
so if you HAD to fit a Holley, the twin-Choke 180CFM unit would be near perfect......
Oh, they are the same bolt-pattern and layout as a DGAV Weber, so there are lots of manifolds out there already.... they just arent very good.....
J
PostPosted: Tue Mar 01, 2005 7:17 pm
A 350 Holley is definitely too big for a Mini engine.
Having tried a 180 Holley and a 32/36 DGV weber on my old Gemini, the Weber was by far superior.
I sold the Weber before I realised it would have worked on a hot 1275... :(
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
 Post subject: Yeah I thought so
PostPosted: Wed Mar 02, 2005 8:17 am
Yeah my brother had one on his 192 in the EH (nice car). Just always wondered about that...
PostPosted: Wed Mar 02, 2005 8:43 am
I see mixed feelings about the downdraft weber. I knew a guy who had a hot lightened flipfront road beast, and he swore by those downdraft webers.
 Post subject: Hollies and why
PostPosted: Wed Mar 02, 2005 9:23 am
Why would you want to replace an SU or weber with one of the worst designed hardest to tune carbies ever made :lol:
 Post subject: Worst Designed
PostPosted: Wed Mar 02, 2005 9:47 am
From what people are saying Holley aren't too bad just not suitable for small engine capacities. The Holley on my brother car ran like a dream with little or no adjustment necessary. I think that makes it a pretty well designed carb. And I would hardly describe the SU as a cutting edge design. Mainly wondered what other carbs might have applications on the 1275.
PostPosted: Wed Mar 02, 2005 10:01 am
I just bought a set of twin downdrafts to go on my honda motor :twisted:
PostPosted: Wed Mar 02, 2005 10:20 am
when people talk about goose neck manifolds they say that the fuel/air bix has to turn to many corners,look at the down draft weber,its gotta turn bugger corners more often :!:
its gotts go down,turn a 90* then another 90*
has GR got a downdraft manifold?
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Wed Mar 02, 2005 6:44 pm
Not that I've seen, and I hang out there a fair bit. :wink:
