It is currently Wed Jun 25, 2025 7:27 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Sun May 10, 2009 10:27 am
Andrew's engine also has 10.5 / 1 comp, modded pistons to suit, capicity is now 1399 cc, lightened steel flywheel and backing plate, rally clutch, hi flow water pump, dry decked head and block { to improve water flow through the block }, s/c close ratio gear set in the remote gearbox, all the lobes removed from the std cam { to clear the crank and reduce the spinning mass}, romac balancer, ajustable oil pressure valve and the list goes on ......
If anyone needs help with these conversions just sent me a pm and i will see if i can help
PostPosted: Sun May 10, 2009 7:20 pm
geez id love that engine
