It is currently Tue Jul 08, 2025 10:55 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Feb 16, 2008 5:38 pm
Well those wheels look great ... "mind if I ask" ... is it an alloy centre mounted inside a carbon rim and can you see the fibre weave in the carbon section or is it painted over ...
-- Simon // VMCI Member 2674 --
PostPosted: Sat Feb 16, 2008 9:40 pm
Whiteski,,, well yes it`s 2x carbon fibre/kevlar composite outer half rims with CNC machined billett alloy centers that all bolt together (3 piece),,, the outer rim halves are made using hi-tech new fandangled Nylon resin & no you can`t see fibre mesh as you would normally within a carbon fibre panel.
PostPosted: Thu Feb 21, 2008 3:39 pm
Matt,
Is there any reason you put the motor so far out in front of the wheels?
Is it just to aid front end grip?
I would have thought it would have a considerable negative effect on high speed balance in a car so light with little in the way of aerodynamic down force. :?
Nice work by the way. :D
PostPosted: Thu Feb 21, 2008 6:39 pm
TheMiniMan wrote:
Nah, everyone else did but me , Some ning nong stole my moulten so i ended up with just a shitty old dragstar but i`m getting my own back now tho hey :-)
Did your dragstar have a T Shifter
PostPosted: Sun Feb 24, 2008 3:21 pm
Mason , yeah it did, but i tossed it away straight after racking my nuts on it when my foot slipped off the pedal one day,,, I just jammed it into 2nd gear after that, with a nail through the change mech in the rear hub :-)
77clubbyVan,,, yeah well there`s actually 4 reasons why the donk is so far forward in the buggy,,, one is that there`s no room left behind there to slip it back any further & 2ndly because the axles are pretty straight as they are now & any further back would make it all yukky & suck power,,, & 3rdly because i`m a tight arse & didn`t want to spend any more money that i already have, so i didn`t make up some eleborate drive mech nor did i buy a quaife type gearbox with reverse gear etc,,, 4thly i just figured that with it a little forward like that the weight transfer would be pretty good going back onto the drive wheels slightly behind
It`s really not that far forward actually, just a tad more than a std mini
& i will be making up an aero downforce package for sure, i`ve just bought all the alloy sheet for that last week :-)
But it will be just a sprint/hillclimb buggy,,, i can`t see me running it down conrod straight at Bathurst if you know what i mean? :-)
PostPosted: Sun Feb 24, 2008 6:47 pm
Be honest if you had the chance you'd take it :D
PostPosted: Thu Mar 06, 2008 11:25 am
You know me pretty dam well don`t you kenno ??? :-)
PostPosted: Thu Mar 06, 2008 7:02 pm
Now really...who wouldn't..I'd even risk the wifes daily drive 8)
PostPosted: Fri Mar 14, 2008 2:34 pm
Hi MiniMan,
Just read this thread today. Great looking "buggy"...very similar to a Motorkhana "special".
Have you thought of setting up the rear brakes for a handbrake and giving motorkhanas a go? They're great fun.
BTW, how's the R1 mated to the Mini drive-shafts? Is there a chain drive to a Mini diff?
Dave[/img]
PostPosted: Fri Mar 14, 2008 5:11 pm
Hi Dave, & yes it`s all set up with a "Fiddle Brake" (4th pedal) for motorkhanas already,,, I did my first motorkhana when i was about 7 years old & been doing them ever since ,,, & as far as we can tell CAMS actually brought in the 14year age limit because of me :-)
Reverse gear is only an electric starter motor set up to the Chain drive assy at the moment so it won`t be very competitive in reversing events, so it`s more of a hillclimb special really, but i will do street & circuit sprints , autocross & drags as well , if they let me that is :-)
Matt
