blownminiturbo wrote:
my cam doesnt have adjustable gears because its a slightly older one but better quality with the full alloy cover instead of plastic like i have seen in the mini mags as of late.. but still should be alot better than the timing chain
I have the same belt drive setup as you.
You can get offset cam keys from MiniSpares from 1-9° in 1° steps, to set the timing spot on.
Once set, you don't need adjustment anyway- the belts don't stretch.
Note the belt needs periodic replacement. Mini Mania recommends at 20,000 miles for the standard belt, or 50,000 miles for their Kevlar belt which I'm running now.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
