It is currently Mon Jul 07, 2025 7:21 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Thu Apr 05, 2007 12:13 pm
Popping core plugs is not an unknown problem in racing engines and it used to be common to tap a small thread in a block and fit a lock tab to each plug.
Core plug popping in normal use could indicate high cooling system pressure, badly installed or incorrect size plug or a damaged block.
Regards
Al
