It is currently Tue Jun 24, 2025 1:20 pm
 Post subject: Turbo 1275?
PostPosted: Sat Nov 27, 2004 7:20 pm
Hey all i need some info on turbo'in a 1275 motor..
I am lookin at addin a turbo to a 1275 motor, just wantin
to know what ill need for this to work?? I want to keep it a
carby setup as changin to fuel injected is just too pricy. So
i was thinkin a 45mm sidedraft webber maby?
Well if anyone could pls give me some info on what needs
to be changed or added for a turbo 1275 pls can you let me know
CHEERS
Daniel
Life's a garden.... Dig It!
PostPosted: Sat Nov 27, 2004 8:55 pm
off the top of my head
Differences include
Compression ratio
Fuel Pump
Fuel Regulator
need a turbo
different manifold
use the metro turbo carby
bulkhead box
head valves and spings should be upgraded
cam should be made to suit
there are more
check out - the turbo mini website www.turbominis.co.uk
research it well
PostPosted: Sat Nov 27, 2004 10:05 pm
Check out this thread.
http://ausmini.tziworld.com/viewtopic.php?t=2995
JW
