It is currently Sat Jul 05, 2025 11:01 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Mon Feb 12, 2007 1:49 pm
Can a A+ tensioner be added to the A series duplex timing set up or is other parts required?
David L
PostPosted: Mon Feb 12, 2007 2:15 pm
Yes it can, but you also need an A+ front plate and its timing cover.
It's made for a simplex chain but will work with duplex.
But GOOD duplex take a long time to stretch, I've never felt the need... :wink:
PostPosted: Mon Feb 12, 2007 5:37 pm
My A+ had the tensioner fall in half! It is a plastic piece on a spring steel back. I was lucky it din't drup down into the crank sprocket. When I took the cover off to replace the chain (because of the bad rattle) the tensioner just fell out in two bits.
Not worth the risk IMO.
M
