It is currently Mon Jul 07, 2025 8:58 pm
 Post subject: over bore size
PostPosted: Thu Nov 23, 2006 6:14 pm
I am doing up an 1100. Whats the max overbore? and what will the capacity be after?.
I have a spare block so when the rings go I will just change it all over. Cant beat cubes right?
blokeinamoke wrote:
PostPosted: Thu Nov 23, 2006 6:32 pm
100 thou over at the moment. Russell engineering are the only ones selling these in Australia.
Aaron
PostPosted: Thu Nov 23, 2006 7:40 pm
"How to Modify Your Mini", by David Vizard has an oversize chart in the blocks and crank section, page 87 to be precise. Also has combination of stroke and bore, so us lazy people don't have to work it out! Says you can fit Imp pistons (Hillman Imp I pressume) and if you go +.040 Imp pistons on a 1098 you can get 1251, that would be rather impressive but may be a bit too big, grab a copy of the book (if you don't already have it) and read up on this section.
 Post subject: vizards
PostPosted: Thu Nov 23, 2006 9:05 pm
hey guys
What is the best version of Vizards book ?
I know I need one, but i have just been slogging away at the body at the moment. Probly looking a little to far forward. Cheers guys again
blokeinamoke wrote:
 Post subject: laws
PostPosted: Thu Nov 23, 2006 9:10 pm
the laws may be a little tighter, but we dont have roadworthys. If I can keep of the loud pedal around the cops and dont get defected and sent to regency(inspection place) I should be ok
blokeinamoke wrote:
PostPosted: Thu Nov 23, 2006 9:15 pm
I have built a few of these motors over the years using Imp standard 68.0mm pistons (back when 1275s were rarer).
It's pretty easy to break into the main oilway from oil pump at back of block with these pistons, never mind +.040" ones..
If you wanna go this big these days, find a 1275...
Good Imp pistons suitable for a thrashing are bloody dear now, I got quoted A$800 for a set of UK ones a while back.
Imp parts in Australia have pretty well dried up. As my brother found out whilst restoring his Imp. 8)
PostPosted: Thu Nov 23, 2006 9:39 pm
we plug & offset drill the oil gallery, easy-peasy
PostPosted: Thu Nov 23, 2006 9:45 pm
So what do you do for pistons Matt- I heard you were playing with Suzuki? bike ones..??
PostPosted: Fri Nov 24, 2006 5:15 am
yamaha pistons form early 80's bike ill find the bike but its a 750cc and has the same crown height and bore size is 68mm.
easy stuff as they are forged and will handle the revs and heat.
did a conversion years ago with a 998 motor and a set of these, it was quick and has never had any hassles in about 500 1/4 mile runs its has had.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Fri Nov 24, 2006 6:22 am
im at 1220 with imp pistons, not saure how it will go, but myengine came complete but disasebled, i wouldnt have done it otherwise.
if you want imp stuf theres a place in NZ called impwerks, they have a website and are very helpfull.
