I said months ago that I would post pics when this was done, and I, with help from my dad did it months ago but its lasted since then so I think it was a good simple mod. As my Lucas 15ACR doesn't charge well enough to keep up with essentail components of the car.
It's rated at 75 A so you can draw more than enough from it. It's actaully a mitsubishi made alternator but from a N15 Pulsar (early 90s i think) was reasonably easy to modify. Required a lathe to machine a pulley to fit it as its flat belt but yeah. Mine is in good condition as it charges at 14.7 volts but only problem (and i'm not the only one) The light doesnt work, but I looked at pulsar diagrams and the reason i think is that it requires a resistor to make a load to make the light function, can't really explain but yeah.
1977 Leyland Mini LS - Project LS-T
