$149.95 for Hypatec oversize 1098 pistons-
http://cgi.ebay.com.au/Mini-PISTONS-AND ... dZViewItem
$100-150 to bore and hone the block
$50 or so to buy a s/h 1100 crank, $140 to regrind it.
Then there's the rest- new bearings, gaskets, new oil pump, overhaul head,
regrind cam (to make it go), bigger/better carbs, exhaust, etc etc.
Oh and don't forget the gearbox- never put an old grotty one under a new motor- strip it and rebuild it.
A mini is a work in progress...
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
