The book didn't actually say if it was a four or a five but it is the same box with a spacer instead of fifth gear so the weight would be fairly similar. (there are a few little bits in the selectors that are different as well)
It does not look like much of a difference in weight but the Auto makes a big difference to the weight over the front end and it is only about 12kg heavier, so the 34kgs of the E-series ohc motor would make a huge difference.
I prefer to remove weight to make a car faster not add it.
