It is currently Mon Jul 07, 2025 10:12 am
PostPosted: Sat Apr 15, 2006 3:02 pm
Umm anyone know the thread of the bolts that attach the dellorto to the manifold?
I got one of those crap house redline 3005 maniflds.. worst casting I've ever seen in my life.
Got a linkage kit aswell, you'd think $100 for a linkage kit, and you would at least get the bolts/studs that attach the carby to the manifold..
Anyway yeah where can I get these?
PostPosted: Sat Apr 15, 2006 3:03 pm
I'm sure you can get them at the same shop as you got the manifold and linkage kit.. the 4 bolts will probably cost you around $50 each.
PostPosted: Sat Apr 15, 2006 3:04 pm
Cool h0nk, thanks for your help.. The place is only a 40min drive, and $50 per bolt sounds terrific.. absolute bargain.
PostPosted: Sat Apr 15, 2006 3:35 pm
You loser Alex :lol: :wink: :P
Lillee - 1969 Morris Mini K
PostPosted: Sat Apr 15, 2006 4:09 pm
Easter weekends were made to be wasted screwing around with mini engines anyway. :)
PostPosted: Sat Apr 15, 2006 5:07 pm
Alex,
Threads are 5/16 UNC or Whitworth?, either will fit in there, thread pitch is the same.
I use the Champion brand UNC ones from Supercrap etc, they are OK.
I bolt Dellortos on with a stock gasket and have never had a foaming/flooding problem.
But, if you are running a soft mount kit (essential for a Weber DCOE, optional with Dellorto DHLA) you want studs and nyloc nuts. :wink:
PostPosted: Sat Apr 15, 2006 6:09 pm
Thanks Kev,
I had some spare 5/16" UNF bolts which I tried, but they started to burr the thread.. I'll go grab some UNC's tomorrow. I'm just going to use gaskets aswell, not the soft mount kit.. cheers.
